filburn
- June 24, 2006
- portland oregon
I have a stock 1992 ford explorer 4x4 with a 4.0 liter engine and automatic transmission. It has 176,000 miles on it and I have only owned it for 10k of those, so I do not know its entire maintenance record.
Here is the problem:
Car starts when cold every time without fail. Once the car is at operating temp and turned off, it has about a 50/50 chance of starting up again. The car cranks fine. starter, solenoid, battery and all that work fine. It peters out once I let off the ignition and the engine tries to take off on its own but it just can't. It sounds like it is going to start every time as in it turns over, but just sputters and nothing. After waiting 20-45 minutes it will start. Once it decides it wants to run, it idles very roughly at first only. I give it some throttle to keep it going and it will eventually run. Once the engine gets going again it runs and idles fine. It absolutely runs 100% (accelerates great/idles great at stop lights).
Troubleshooting I have done:
I searched the forums and found a lot of great information. I did find a couple posts that were very similar, but had some different symptoms. I carefully cleaned the MAF sensor and the car ran the exact same. I changed the air filter. I changed the fuel filter and that didn’t do it. I cleaned the IAC so it moves freely and that didn’t fix it either. My fuel pressure at the rail reads about 20psi when charged with the car off and it reads 30psi when the car is running.
Any suggestions would be appreciated, but keep in mind the car runs fine once it has been started. So it has to be independent of the engine running mechanics and is temperature sensitive.
Thanks for reading,
Thanks for reading,
