Jon Burns
- July 6, 2002
- Wolverhampton, United Kingdom
- 1997 4.0 V6
Hi Guys,
I really could use some help with this. I have searched extensively but just can't find anything which helps with this problem.
I have a standard 1997 sohc 4.0 liter Explorer in RHD which is as far as equipment levels go somewhere between an LTD and an Eddie Bauer, I think. I recently replaced the magnetic sensors on the transfer box that determine front and rear axle speed as well as the transfer case switch motor. This was because the car would not engage 4WD and would only run in 2WD. We can now get the car to select Auto and 4x4 Hi but it will not select 4x4 Lo under any circumstances. Worse if you try the system goes haywire and you have to stop the car and disconnect the battery for a period. On reconnection all is well so long as no attempt is made to select low range. When the car malfunctions the 4x4 lights on the dash flash 5 or 6 times every couple of minutes.
I love my Explorer and I'm trying desperately to solve this rather than junk it and buy a Merc or something Japanese. I'd be really grateful if anyone has an idea about this.
