Front airbag sensor location | Ford Explorer Forums
golfboy
99 Mountaineer
I replaced my front bumper because I "bumped" something while off roading :D
Anyway, when I pulled the bumper there is a switch that I assume is the airbag switch hanging loose behind the left (driver) side foglamp. It is a threaded switch with a button on the end.
I did a search on this forum and saw where the switch is suppose to be located. I pulled the plastic header but can't find where this switch is suppose to be mounted. I assume that the button is suppose to be pointed forward (toward the front bumper) but can't find anywhere where this switch would be threaded, or anything.
Can someone clarify for me where this switch mounts? My manual doesn't even show it.
Thx
it is straight up from the frame rail. Bolted to the metal core support.
It is about an inch and a half squared box on a bracket that is about three inches long.
It should have a yellow connector.
