2TimingTom
- October 12, 2010
- Location
- Littleton, CO
- Littleton, Colorado
- '97 XLT
With the truck completely off the ground, transmission in neutral- how easy should the front axle be to rotate?
And on a potentially related note, what would cause 3 areas of significant resistance while rotating the front left wheel which also cause the corner (upper/lower control arms, axle, brakes...) to rise about an inch? I removed the brake pads and it remains the same. The right front doesn't rotate as smooth as the rear wheels, but it rotates with much less resistance than the front left.
Any ideas?
I've also been having an issue with a weird smell that seems to be originating from the left front.
Also when turning, I can't tell if it's the BFG All-Terrain T/As being loud or there's another issue.
Got a front axle starting to crap out on me?
Any ideas?
