Front Blower Motor Not Working | Ford Explorer Forums
Kkat955
Bayville,nj
2016 explorer xlt
Hi I have a 2016 explorer and tonight driving home the front blower defroster wasn't working. Had to keep the rear on high to heat the truck and keep front window defrosted. Could it be a fuse? If so where is that located. Looked in book had a - in size. But the other climate control had a fuse size. Would that be it?
Welcome to the Forum.:wave:
As per the Owner's Manual, check fuse #43 in the engine bay fuse block.
Thank you :wave:.
I am assuming those are like any other fuse and I will be able to tell if it is broken. I won't need a special tools to either get to that fuse block or to take the fuse out they just pull out right?
Thank you :wave:.
The Manual will tell you what kind of fuse it is. I've never opened the fuse panel but I'm guessing it should be fairly straight forward.
