front diff | Ford Explorer Forums
front diff
Retardriot427
Lynchburg, VA
1993 Explorer
ive got an early model explorer (93)....is it just me or am i the only one having clearance problems with obstacles with the front diff.
they hit a lot without a lift... but i have found they slide over a lot too.....
what kind of lift should i get to help this clearance problem.....keeping in mind i want to get either 31x10.50s or 32.11x50s
i have 31s under mine stock..... the only way to raise the clearance problem is with bigger tires.... all the lift in the world wont give you clearance.... but bigger tires will
if i get 31x10.50s what would be a good size lift to get so it wont rub even when im off roadin
the F150 spacer / warrior shackle lift should give you plenty of room. there are zillions of posts on the topic, try the search feature.
