Front differential | Ford Explorer Forums
Front differential
1st Ford for me
Vashon Island Wa.
1993 Explorer Eddie Bauer
Front differential feels like it is binding an and clunking in 4w low and high
If you haven't already, you might want to check the front axle u-joints. I was getting a lot of noise that I thought was coming from the diff, but turned out it was fine, and problem was the u-joints were both completely bound up with rust. Still was a lot of work to replace them and the seals, wheel bearings, etc., but didn't require going into the diff at all.
Thank You very much ! I'll check it out.
No, backing up a slite grade on a gravel road.
If you still have auto hubs, it’s probably the hubs.
