koda2000
- September 2, 2011
- x
Update:
It actually hasn't rained yet today, so I crawled under the truck with a flashlight. The front prop shaft CV boot is blow out and apparently has been for a while. Perhaps it's been changed before, as it had 8mm bolts and not Allen head bolts. The CV bolts came out w/out a struggle, but so far I've only managed to remove one front u-joint strap bolt before my cheap-ass socket snapped. I just got back from NAPA with a quality T30 socket, but it's about to rain again, so It will have to wait until tomorrow. Perhaps I'll heat the remaining strap bolts with my map torch for a few seconds, as the one that came out had red thread locker on it (Ford loves that stuff).
Just twisting the front drive shaft back and forth makes the CV joint rattle, so that's definitely the problem. The front u-joint seems to still be okay so I'll leave it alone. This truck will not be seeing much use in the future, other than weekend hauling, so it should be fine.
I still haven't decided what to do about the front diff cover leak, but there's no way it's coming off without moving the diff back at least a few inches. I'll worry about that later. There seems to be 3 bolts/bushings holding it in place.
