Front Driveshaft Seal | Ford Explorer Forums
Sallad420
Kelowna, BC Canada
'96 XL 4WD
Hi all, i just got my oil changed and I was told that my Front Pinion Seal was leaking.
I tried to look in the Hyanes repair manual to find how to fix it, but I couldn't find anything.
My question, can you just go under the truck, pull the front driveshaft off, slide out the front drive spindle (or whatever it's called) and replace the seal?
or do you have to completly take the front diff apart?
My only concern is if I just pull the front drive spindle off, will any gears slide off inside? or is everything supported by something else inside the diff?
Thanks in advance...:)
search for pinion seal.....Its supposedly not to hard a job. Couple threads on people replacing the seal.....pay close attention
Thanks!:D
