front end creaking | Ford Explorer Forums
front end creaking
5.0 guy
baltimore, maryland
96 5.0 2wd
The front end on my 96 5.0 2wd is creaking. It seems to be coming from the "A" arm bushings. I tried to lube them with spray lube but it hasn't helped. Does anyone know what I can do to stop it? It makes the truck sound like a piece of crap. Is there a quick fix or do I need to replace the bushings?
welcome to the site.... if it is the bushings, replace them... also, examine shocks, as they cause creaking up front as well
I found my squeeking and rattling here. At first, I thought the sounds were coming from the front end. You might want to check it out.
Also, check your front swaybar bushings.
I had front end sqeaking and I never thought it would be the swaybar. I replaced the bushings and the sqeaking is long gone.;)
That is true. In my case, I changed the whole sway bar end links to a shorter one. It did not fix the squeeking noise but I discovered by going to a shorter end links it made my truck corner better. :)
Thanks for the info. So far I haven't had any luck determining the exact problem.
Just keep going at it man. You'll find it eventually. Or it will fall off eventually. :D
I swore I found my creaking several times and lubed up every spot, one a day..and was wrong each time. My creaking came from inner tie rod ends and was fixed with WD40 using a small pin hole in the boot. Then seal hole with silicone caulk. No noises anymore. My creaking was much worse when it got warm.
Hope this helps a fellow baltimoron.
I finally narrowed it down to either the inner or outer tie rod ends on the passenger side. I lubed the inner end through the boot and replaced the outer end with one that has a grease fitting. So far so good. Thanks for everyones input, it is appreciated.
