EMBPilot
- November 29, 2006
- Jersey Shore
- 2007 Ranger 4x4 XLT 4.0L
Hey Guys,
Need some help with a noise that started a few weeks ago.
1998 (built october 97) XLT AWD 5.0L 125K
Once i start accelerating from the stop with the wheels turned (hard) (left or right) the truck has a groaning, grinding sound that will "roll with the wheels" (the noise will fade in and out as the wheels turn) all through the turn, and during acceleration until the you start taking out the turn. once the wheels are straight again, the noise goes away. it definitely sounds like its coming from the front end.
if your rolling, at ANY speed even 3MPH, and turn, HARD or Soft, there will be NO noise from the truck. it has to be done from a stop and usually only while accelerating from a stop during a turn. If you accelerate from a stop, and go straight, no noise either.
it will not do it in reverse either.
Im not even sure where to start looking here. i was thinking maybe start with a front gear-oil change? maybe wheel bearings? the sound has defiantly gotten worse as i continue to drive the truck. It is my daily driver.
Thanks for your help guys.
Kevin
Kevin
