Front end Loose | Ford Explorer Forums
Front end Loose
bnpain
Malden, MA 02148
1997 ford explorer 5.0
Back in 03 I replaced my oem anti sway bars (front and rear) with double the thickness on my Explorer 97 5.0 AWD with an Addco aftermarket kit. This made the truck handle like a sportscar, hardly do any braking in turns and accelerate out of them and recently while on Storrow Dr. in Boston with those tight s-turns it felt as though something was loose up front ( like the front end was floating, tought I was going to hit the wall. I recently replaced the front stab. end links and upper balljoints. I rechecked my install and all OK, no play at all in front end so decided to look at the rear the endlink bushings worn out. I'm going to install with eurathane but could the symptoms up front be due to the rear bushings being bad???
