Drewmcg
- August 27, 2015
- Location
- Michigan
- Ann Arbor, MI
- 2010 XLT 4WD
2002 XLS 2WD
My 2010 Explorer 4wd sounds like it needs a new driver's side hub/bearing. The front axle seal on that side has been leaking for a while, so I want to tackle that problem, too.
The YouTube videos, etc., have you removing the knuckle in order to pull the CV shaft to replace the axle seal. Question: Since I'll be removing the hub (which does not require removing the knuckle), can I pull the CV shaft out through the hole where the new hub bolts in, without removing the knuckle? Or is that hole too small to pull the CV/axle through?
