front hubs | Ford Explorer Forums
front hubs
garagedog369
Location
egan south dakota
egan south dakota
94 explorer 4 wheel
i was just at a ewe pullit auto recycler. was looking for front hubs or anything i could pull. i started to notice diffent fords with manuel loocking hubs. what models should i look for to replace my auto hubs i a 1994 explorer.
Make sure the donor axle is a Dana 35 with the correct spline count and you will be fine. The Rangers also had the Dana 35 front axle, but also had a Dana 28.
Slip the manual hub over the Explorer axle shaft. If it slides on, you are good to go.
Also get the hub retaining hardware since the auto hub hardware is different.
I have a '93 with manual hubs, so certainly 91 - 93 Explorers would be a source.
