Wanted - Front Suspension Bits | Ford Explorer Forums
Wanted Front Suspension Bits
Parts or services wanted
ihpj
1998 UK SOHC Explorer
Since I am planning to replace both my upper balljoints I have been rooting around under (and around) my Ex. and noted that on the OSF it has the two piece setup.
Due to the heavy rust I reckon I will not be able to separate the two pieces. My best option would be to remove the entire assembly and junk it. I have the part with the balljoint itself, but what I need is the other half of the arm as well as a set of aligning bolts that hold the arm to the chassis.
Can our usual suppliers help please?
If you're looking for new, I used Rockauto. I replaced both uppers with single piece arms, and installed the camber adjuster bolts/cams. The price isn't so bad, and with the Moog arms the ball joint is replaceable unlike the stock ones
Wish I had paid this more attention when I bought a truck load of parts when I was in the States last year! No I don't want new as I just need the metal arm itself. I have a new ball joint. Hoping ChrisQ is breaking a good Ex. with a good used part.
top arm
hi its me.
can do the inner part of the 2 part top arm with bolts for £20 inc P&P.
cheers chris
hi its me.
cheers chris
Sounds good!
I forgot to add, in addition to the set of aligning bolts needed, I will need a set of bolts that affix the two pieces of the arm together as well. Can you toss in a set please? Will Paypal you the money.
can do the conecting bolts with it. cheers chris
Will Paypal.com you the monies tonight!
EDIT: Monies sent!
Got the bits this morning, thanks ChrisQ!
Just wanted to say 'thank you ChrisQ' part fitted (with a whole bunch of new bits) - my ball joints etc. so pretty badly shot TBH and I'm glad I replaced them when I did.
Anyways, thanks again big guy!
