I have replaced mine with HUB-67 on my 06 many times. They fit just fine.
Ok, so my curiosity got the better of me. Per the "more information" data on RockAuto (taken right from Timken's website), there are subtle differences between the two Timken front wheel bearing/hub assemblies (i.e., between 3rd gen and 4th gen). See
TIMKEN SP470200 (3rd gen):
ABS/Non-ABS (Y/N) Y
ABS Type SENSOR
Bearing Type Tapered
Bolt Circle Diameter B (in) 4.500
Bolt Circle Diameter H (in) 4.331
Bolt Size (in) M12x1.75
Brake Pilot Dia (in) 3.226
Driven_Non Driven Driven
Flange (#) 2.000
Flange Diameter (in) 6.299
Flange Offset (in) 1.927
Flange Shape Modified
Generation Type 2
Hub Pilot Dia G (in) 3.350
Roll Form (Y) Y
Spline Quantity 27.000
Wheel Studs (Y/N) Y
Wheel Stud Size (in) 43832.000
Alternate/OEM Part Number(s): 3L2Z1104AB, 4L2Z1104AA, SP470201
Vs TIMKEN HA590156 (4th gen):
ABS/Non-ABS (Y/N) Y
ABS Type SENSOR
Bolt Circle Diameter H (in) 4.449
Bolt Quantity 3.000
Brake Pilot Dia (in) 3.228
Flange (#) 2.000
Flange Offset (in) 1.921
Flange Shape Triangle
Hub Pilot Dia G (in) 3.346
Roll Form (Y) Y
Wheel Pilot Dia (mm) 70.450
Wheel Stud Qty 5.000
Alternate/OEM Part Number(s): 6L2Z1104A, 7L2Z1104A
Whether the subtle differences make a difference, I don't claim to know.
I sure wish/hope that they were/are functionally identical, since the 3rd gen part is $50 or so cheaper than the 4th gen part. In an abundance of caution, I'm using the 4th gen part for a bearing that is making early signs of failure (132k miles), and saving my WJB HD for the other side down the road, where it will (hopefully) have to last a few less ten-thousands-of-miles!
