IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
My shuttle bus came with a Seltec A/C compressor (TM-16HS) for the auxiliary A/C unit. Well that compressor is pretty much dead and I want to convert it to a compressor which is easier to find at local part stores. I checked the specs on this Seltec compressor and it is pretty much the same as a typical Ford FS-10 unit (displacement) and the in/out ports on the back are compatible. So overall, it sounds like the FS-10 will work just fine (just have to weld up a new bracket).
My question is: am I right to assume that the two pins on the FS-10's connector are purely for the compressor's clutch and nothing else?
I can pretty much assume it is (since there's no other electrical parts) but I just wanted to make sure.
