For your first question, if you want to test the PSI coming from the filter, downstream from the filter to the engine, there is a a testing point for that. The flow goes from the pump to he filter, then to the pressure test point, then to the injectors, to the regulator, and then back to the tank. Test the PSI at this point. ll you have to do to test is to plug on the PSI and then turn the key to the on position. The pcm tells the pump to run, and if the starter doesnt fire, it turns off in like 1.5 seconds. Thats all the pressure time you need for a reading, but I suggest turning the key 3 times. It will not make the pressure higher. You should readbetween 35 and 45 psi, which is spec. ou can also hotwire the rightside pin on the connector for the ODB1 tester. with the angles upwards while looking at the connector, short the right side slot to the vehicle ground and your fuel pump will stay running when you turn the key on.
he IAT is the intake air temp resistor sensor. Lets the pcm know how cold the air is. Hearing a better desc from you, I would advise to pull the whole air intake system out. The black tube to the box, then the box, then the vent connected to the box. There is a tube which brings warm air from the engine to the box, and it has a valve control which will keep the vent open from the engine if the IAT is bad. You can ohmmeter the iat to see if its bad... I can explain that later. Check the foil tube from the engine to the lower arm of the intake... it brings air from the grill to the bottom of the filter box. Check for debris. Oil the valve in there LIGHTLY. If you hear noise from the box just when you start, it may be that valve not working. The Purge Solenoid controls the movement of that item and that should be checked too. See if the T on the end of it is clogged with goop. If it is, replace it and the vacuum lines to it. The Purge Solenoid is the only component inbetween the air intake manifold and the engine block, and it is visible from the drivers side of the engine, just below the IAC area.
