CrAzEd412
- June 12, 2007
- Berryville,VA
- 96 Explorer XLT 4.0L 4wd
Hello all,
First let me begin by expressing my gratitude that this website exists! It has saved me a lot of money and time trying to fix problems on my aging Explorer.
The problem that I am experiencing currently is my fuel gauge registering past full. I've searched countless times and spent many hours trying to find someone else who has had the same issue. The threads that I have been able to find helped at first but the problem still remains. I've already been through 3 fuel pumps (all Spectra Premiums from Autozone), the current fuel pump in my Explorer being a Spectra. I would love to put an OEM Motorcraft pump in the tank but cannot afford it at this time since I am still in college. This being my 3rd fuel pump I am at my wits end trying to figure out why the fuel gauge is giving a reading past full.
I recently replaced the fuel pump about 2 weeks ago while trying to fix the issue after I had replaced the instrument panel from a junkyard Explorer. Thankfully I was still under the 1yr warranty for the old pump as it had begun to make a very loud hum noise that could be heard outside and inside of the vehicle. Not only did it have the loud hum, the noise began to fluctuate and almost hesitate to run like it was on its way out. Long story short, dropped the tank replaced the pump with a new one thanks to the warranty (pissed I had to drop the tank again in less than a year to replace it). Before I put the new pump in I made sure it was giving the correct ohm reading by moving the float up and down, put the new one in and buttoned everything back up. Filled up the tank and the gauge was reading correctly, worked great for a few days but on my way home from work I noticed that it had begun to creep back up past full. I know I didn't have a full tank, at that point I had about 1/2 tank. The odd thing is if I let it sit overnight the needle sometimes drop down to the correct fuel level other times it won't and will stay past full.
Also have a problem with my Explorer shutting off randomly sometimes(while driving) or not even starting up after driving for a little while, this I narrowed down to the fuel pump relay (replaced 2 times). When it shuts off I pop the hood, pull out the relay and tap on it plug it back in and it starts right up as if nothing was wrong. I talked to a buddy of mine about the issues I'm having and he thinks I could have a possible ground short somewhere.
I apologize about the length of this post but like I said I am at my wits end as to what the problem is. Figured it would be easier for me to write up all that I have done in order to narrow it down and find a fix to my issues.
Thanks!
- Jeremy
Thanks!
- Jeremy
