Fuel gauge question. | Ford Explorer Forums
TwiztidRat
blah
blah blah
Hey guys always been curious about the fuel gauges on these trucks.
The red line next to E. Does the needle go below that when you are almost empty? I go in panic mode when it's that low my 'check gauge' light doesn't come on, and I was told it does when you're real low. I don't like to take my chances and run it lower and risk burning out my fuel pump. I know I have about two gallons left though even when the needle hits E.
I have driven till the needle is below the E a few times but my tank is dented so my needle could be off.
mine goes just below the red then the check gauge light comes on
Once the needle enters the red zone, I figure I have about 4 gallons left.
When you're getting near "E" fill a gas can and take it with you. Then keep driving until you run out of gas. That's the only way to know for sure. A fuel gauge is a pretty crude instrument and different factors can effect its reading. You can park on a hill nose-down and run out of gas because the pump pickup is in the far rear of the tank. Typically, you're going to be down to a couple of gallons by the time the "Check Gauge" comes on, but not all if that is going to be usable.
I ran my tank down to change my fuel pump. I carried a can of gas with me just in case I ran out (I didn't). When I pulled the tank and emptied it completely, there was about 1 3/4 gals left in it. I have a 24 gal tank and according to the gauge and the trip computer, each division marking on the gauge should be about 6 gals and it seems to be fairly accurate. When I reinstalled the tank, I put in 12 gallons and the gauge registered exactly 1/2 on level ground. To be safe I never wait until the needle hits "E". I don't see the point, as you're gonna have to buy fuel anyway, but it's nice to know how low you can go just in case.
I just wasn't sure if the needle went below that red line or if it stopped there.
