fuel pressure regulator screw in or not? how do you tell | Ford Explorer Forums
bad.shimmy
auburn wa
91 eddie bauer
any way to tell if it's a screw in type regulator or a push in with a couple bolts type connection.
can we tell with the regulator still installed numbers on it or maybe something from the vin #?
thanks all
j
The FP Regulator has a screw in fuel line, push on vacuum line, and two screws holding it to the fuel rail. On my original motorcraft there was a part number on the top.
Ther '91 and the later 1st gens use a different FPR.
The FPR on the 91 motor I rebuilt would not fit on the fuel rail from our '92 truck. The fuel line as it connects to the FPR is different.
I think I still have the '91 FPR if you want the ford part # off it.
~Mark
thanks maniak. but it turns out that the fpr is still good on my ex. the line i had hooked up to my vacuum gauge was too big switched lines and it tested good. good pressure and everything.
thanks again guys.
