Expl01
- June 16, 2011
- Location
- Southern Cal
- Long Beach, CA
- 01Expl XLT 4.0V6 2 WD 4dr
Hey everyone,
My engine will not start and I need help.
It is a 2001 XLT, 4.0 V6 SOHC, A/T, 2WD
The engine will not start apparently due to excess gas [massive “flooding”]
So far I have found the following:
It cranks strong, so battery, starter & ignition all work well.
It has spark at the plugs
It has good compression
The timing is correct.
The plugs were wet when I pulled them
There is a strong smell of fuel when it is cranked even for a few seconds
There was liquid gas at the throttle body hose connection.
If I have a bad Fuel Pressure Regulator that is causing flooding so that the engine will not start [and yet sets no codes?], is it possible to add an aftermarket FPR in the line between the fuel filter and the Schrader valve?
I am thinking that if the stock FPR is causing too much fuel, then it has failed “open” and there is always too much pressure [I have recently replaced the Fuel pump, so this is near new and should last several years], as opposed to not enough pressure or no pressure. Since it will always have more than enough pressure, what can it not be controlled by a secondary FPR installed into the line. Why? Well this would not only save me pulling the tank to change it [since I have a 2001], but it will save me the $300+ it will cost to get the whole module from either Ford or the parts stores, which offer the same type of replacement at a similar cost.
I am hoping for some insight or experience from anyone who has any familiarity or exposure to these things or similar problems. Any suggestions will be greatly appreciated. I understand Carburetors [like Holley double pumpers], but if this is a learning experience, I must be a slow learner.
Have a happy Fourth of July, Happy Birthday America!
Jake
01 XLT
GT-350
_________________________________________________________________
Jake
01 XLT
GT-350
