fuel problems | Ford Explorer Forums
fuel problems
kbcrazy
Monroe Louisiana
are 1991 ford explorer has been cuts out and dies. we have replaced the fuel filter and the problem got worse. we have bought a fuel pump and looking for the instrustions of how to put it in. my daughter is ill and we need the car if anyone can help we would be greatful :(
unfortunately, the fuel pump isnt very easy to get to - i think you usually have to remove the gas tank - which is a pain.
here are some instructions on how to do this (from AutoZone's website):
http://www.autozone.com/servlet/UiB..._us/0900823d/80/0b/9a/5d/0900823d800b9a5d.jsp
the following thread discusses fuel tank removal with some links to images near the end of the thread:
http://www.explorerforum.com/forums/showthread.php?t=142621
here's some more to read:
http://www.explorerforum.com/forums/showthread.php?t=98725&highlight=fuel+tank+removal
http://www.explorerforum.com/forums/showthread.php?t=137590&highlight=fuel+tank+removal
I have replaced my fuel pump twice in the 8 months I have owned it, long story. I am now very good at removing/installing. You will have to drop the tank, not fun or easy, unless you have a full frame lift. If you have the tools and the willingness to do it, I can help with whatever questions you have. Make sure you have a fuel line disconnect tool before you start tho, its a pain to have to stop in the middle of things and run to the store. I would make sure that the pump is the problem first tho, could be the fuel pressure regulator. Let me know.
Have you replaced the fuel pump relay? It's a lot easier and cheaper than the pump, and it could be your problem. Also, have you checked the fuel pressure to verify that it's a pump problem?
