pathwayus
- October 11, 2011
- wnc
- 1992 Blue Explorer
A few week ago with some help hear I end up replacing the fuel pump in my 94 x. Last Friday I was able to tag and but her on the road after working on her all fall. The first two day I drove it Every thing seem ok other then being a little slow going up hill. The next day I pull in to walmart to get some stuff walk back out and start up and start to turn around it bogged down and died. After five hours got it started and drove home but couldn't go push the throttle over 3/4 or it would start to bog down as soon as i let up it was fine. The next day it did the same thing when I was going out the drive way. Once again i worked with it and got it to start. So today i changed the fuel filter witch was full of dirt. I started it up and ran I took it about a mile down the road and back and was anytime you would push the throttle over half way it would bog out. When I pulled in the drive I turn it off and restarted it and it hardly runs. This lead me to believe the pump is bad (again). I guess next time ill by a new one and not go to pull a part for it even if it does look new.
