- May 13, 2000
- Cape Girardeau, MO
- 94 Sport 4x4
If you read the Power Foam threads, you'll see all of this info. It's good to have it repeated though, it can't be stressed enough that if your truck is designed to run 87 octane, then you should run 87 octane.
If you have a chip programmed for 93, then you should run 93.
Running 89 or 93 octane in a vehicle set to run 87 will increase the rate of carbon buildup.
