Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Moderator Emeritus
- February 19, 1999
- Mount Vernon, WA
- 1st Gen XLT 4dr
- Callsign
- KG7VTT
I am starting a full 4.0lL rebuild out of a 91. I plan to use the comp street grind cam, replace all the normal stuff with a rebuild and then add some headers and a high flow cat. My question is, would boring it out add more HP or torque? If it doesn't I don't need to spend the money. If it does, will the stock injectors be enough and do I need a custom chip?
