Fuse block identification | Ford Explorer Forums
advachiel6
Zanesville OH
1998 LXT V-8
I can't find a diagram that shows all the fuses in the block under the air cleaner box. Also, all fuses for the horn are OK and I swapped relays, but still no horn. Any ideas?
You have fuses on the drivers side of the dash. Also under the hood in the power distribution box. You have relays in a box under the dash.
Get a meter and see if you have power at the horn when it's pressed. It could just be your horn is shot.
Fuses
Thanks for the reply. I should have stated that the horn worked for a few days after replacing all the fuses and relay, but then quit. Will check the relay in the box under the hood, again, and try the meter route. Also, I took the panel off under the steering column and there was no box with a cover like is shown in a diagram. All there was is a steel plate. Could it be somewhere else? The fuse box under the air cleaner box contains the fuse for the windshield washer motor, but none of the others are identified. Can you help?
