welsh
- March 24, 2016
- 2002 Explorer
I've been posting my problem with no results so I thought I'd ask for a solution in another way. Both the cluster and the sender have been replaced with out any change to an "empty" reading on the gauge.
- Is the wiring from the sender to the cluster a straight run, or are there any connectors in between the cluster and the sender?
- Would it be worthwhile to run new wiring (ground and power) from sender to cluster?
Thanks
Thanks
