Gasket between exhaust manifold and Y-pipe? | Ford Explorer Forums
Jon94
Guilford, Connecticut
94 Sport
99 Explorer 4.0 OHV - are there gaskets between the manifolds and the Y-pipe? I have an exhaust leak right at that joint on the passenger side and was wondering if I could replace that gasket to fix it. If there's no gasket, how can I fix it?
My 1996 and 2004 do not have gaskets in that location. You may have loose studs or nuts or rust build up causing your leak. This connection is just metal on metal.
