Gauges | Ford Explorer Forums
Gauges
Prostar
99 explorer
Does a 1998 Explorer Sport have a low fuel warning or is it just the check gauge indicator. Also my headlight icon on the dash panel does not work, is there a quick fix or does this mean the light in the back of the panel needs to be replaced.
Thanks
Check gage light.
By headlight icon, do you mean the high-beam one? It's only on if the high beams are, if it doesn't, the bulb is probably blown and needs to have the cluster removed to change it...
