gear oil quanity | Ford Explorer Forums
gear oil quanity
nitris
Atlanta, Ga
1991 Ford Explorer 2WD
how much gear oil do the 91 3.73:1 take? I have searched this forum only to find debates about the type... I have tried looking in the manual with no luck... how much gear oil does ford say this truck take? is it 2.75 quarts?
Fill it up until the fluid level reaches the fill plug.
As with any fluid, check with the truck level. Also make sure the axle vent hose is clear, critters have been known to blow axle seals.
truck is leveled i filled while it was on the ground and hose is clear... thanks again
