Gear Ratios | Ford Explorer Forums
Gear Ratios
VBVA
Go Dukes!
Northern Virginia
'93 XL
Ok, I searched for the answer, but I couldn't find exactly what I was looking for. I want to know my stock gear ratios in my axles. I have a '93 XL 4.0L push-rod engine (I think). What ratio am I running, or how can I find this out? Thanks.
B.L.
There is a code on your door. Then do a search by Axle Code and you will get your answer...
J
Look at the build tag on the end of your drivers side door and look where it says "AXLE" note the code you see then click on this link: codes
