Gearbox noise | Ford Explorer Forums
Gearbox noise
YORKSHIRE, ENGLAND
97 4.0 SOHC
My X has 76,000 miles, bought it with 40,000 miles
Always had a whine in first & second gear, not loud but there.
The last two thousand miles second gear has got abit louder,
Is there anyrepair/service I could do at home (dont trust the dealers) Filters ,fluid,adjustments.
Everything works great, shifts are smooth up & down,its only on take-off you notice the whine
thanks
Have you tried replacing the fluid. You may try a full synthetic oil. That is about the only cheap fix.
Great , Ill give it a go
I heard that its a good idea to empty the torque convertor by draining the pan first then start the engine and watch for the fluid , but being carefull not to run it dry.
good idea or not ?
