General Maintenance Question | Ford Explorer Forums
stiffaknee
Atlanta, GA
2002 XLT
I have a 2002 Explorer xlt, and I love my car, she's my baby. I want to make sure she lasts me a good long while (she has 142,000 miles on her) so my question is, other than routine oil changes and stuff, what maintenance is truly necessary? (P.S., I have car hypochondria, meaning i hear a noise and I think the absolute worst! I am also incredibly suspect of mechanics-I still have this notion that I'm going to get taken advantage of)
I'm also concerned about transmission issues-are these even possible to avoid?
Thanks y'all.
Welcome to this forum! Check the belts, hoses, use clean filters, and always maintain the correct fluid level. Clean the mass air flow sensor, idle air control valve, and the throttle body. Add a stacked plate cooler, and an external filter for the transmission.
What is a stacked plate cooler, and where do you get one? Do you have to ask specifically for the mass air flow sensor, idle air control valve and throttle body to be cleaned? How do you know when you need new belts and hoses?
I have a recall out on my car, should I just ask the dealership to do all that when I take it in?
The maintenance schedule is designed to protect against major repairs resulting from neglect or inadequate maintenance and to prolong the life of the vehicle.
General Maintenance Information
NOTE: This is a generic maintenance schedule for all Ford, Lincoln and Mercury vehicles. There may be items listed that do not apply to all vehicles.
The Normal Schedule applies to operation of the vehicle under typical, everyday driving conditions. The maintenance frequency in this schedule typifies what the vast majority of vehicles will require. The listed services should be carried out at specified mileage intervals. There are, however, additional services required that only the noted vehicles require.
If the vehicle is operated in one or more of the following special operating conditions, those additional services will be required. The special operating conditions are:
towing or carrying heavy loads.
extensive idling and/or driving at low speeds for long distances.
driving in dusty conditions.
off-road operation.
There are also exceptions to the Normal Operating Schedule which will require more frequent maintenance for some components. Those exceptions are:
natural gas and propane vehicles — fuel tank intervals.
normal vehicle axle — maintenance and lubrication.
police and taxi vehicles — maintenance and lubrication.
engine oil and yellow coolant — time and mileage-based interval.
Special Operating Condition Requirements
When towing a trailer or using a camper or car-top carrier:
Change engine oil and install a new oil filter every 4,800 km (3,000 miles) or 3 months.
Change transfer case fluid every 96,000 km (60,000 miles).
Change manual transmission fluid as required.
Inspect and lubricate U-joints as required.
During extensive idling and/or low speed driving for long distances, as in heavy commercial use such as delivery, taxi, patrol car or livery:
Change engine oil and install a new oil filter, lube front lower control arm and steering linkage ball joints with zerk fittings (if equipped) every 4,800 km (3,000 miles) or 3 months.
Inspect brake system and check battery electrolyte level (Patrol cars) every 8,000 km (5,000 miles).
Install a new fuel filter every 24,000 km (15,000 miles).
Change automatic transmission fluid, lubricate 4x2 wheel bearings, install new grease seals and adjust bearings every 48,000 km (30,000 miles).
Install new spark plugs and change transfer case fluid every 96,000 km (60,000 miles).
Install a new cabin air filter as required.
When operating in dusty conditions such as unpaved or dusty roads:
Change automatic transmission fluid every 48,000 km (30,000 miles).
Install a new engine air filter as required.
When operating in off-road conditions:
Inspect and lubricate U-joints.
Inspect and lubricate steering linkage ball joints with zerk fittings.
Checks and Services
Certain basic maintenance checks and inspections should be carried out at specified intervals. Any recognized adverse condition should be corrected as soon as possible.
Maximum Oil Change Interval (Normal Schedule)
8,000 km (5,000 miles) or 6 months, whichever occurs first.
Maximum Oil Change Interval (Special Operating Conditions)
Monthly Checks
Check each of the following items every month:
All interior and exterior lights.
Tires for wear and correct air pressure.
Engine oil fluid level.
Windshield washer solvent fluid level.
Check and drain fuel/water separator.
Six Month Checks
Check each of the following items at least every six months:
Lap/shoulder belts and seat latches for wear and function.
Spare tire air pressure.
Power steering fluid level.
Parking brake for correct operation.
Safety warning lamps (brake, ABS, air bag, safety belt) for correct operation.
Coolant system fluid level and correct strength.
Battery connections. Clean if necessary.
Clutch fluid level, if equipped.
Windshield washer spray, wiper operation, clean all wiper blades.
Lubricate all hinges, latches and outside locks. Inspect for correct operation.
Lubricate door rubber weatherstrips. Inspect for excessive wear.
Clean body and door drain holes. Inspect for clogs and obstructions.
Special Checks (Mustang Only)
Carry out the following check every 8,000 km (5,000 miles):
Adjust clutch by lifting pedal (manual transmission Mustang only, as described in owner guide).
Normal Schedule
The following checks or procedures should be carried out for all cars, minivans, light trucks, sport utilities, vans, 4x4s, natural gas and propane vehicles.
8,000 Km (5,000 Miles)
Change engine oil and install a new oil filter.
Rotate tires and inspect for wear.
16,000 Km (10,000 Miles)
Inspect tires for wear. Rotation recommended for optimal tire life.
24,000 Km (15,000 Miles)
If equipped, inspect automatic transmission fluid level with dipstick.
Inspect brake pads, shoes, rotors, drums, brake lines, hoses and parking brake system.
Inspect wheel ends for end play and noise.
Inspect engine cooling system and hoses.
Inspect steering linkage, suspension and (if equipped) driveshaft and ball joints.
If equipped, install a new cabin air filter.
32,000 Km (20,000 Miles)
40,000 Km (25,000 Miles)
Drain coalescent fuel filter and replace filter (NGV).
48,000 Km (30,000 Miles)
Inspect exhaust system and heat shields.
Install a new engine air filter.
Install a new fuel filter. (See ADDITIONAL INFORMATION below.)
Change automatic transmission/transaxle fluid on all vehicles equipped with AX4S, 4F50N, 4R100, 4F27E. Inspect automatic transmission fluid level using dipstick on all other vehicles, if equipped.
If equipped, install new climate controlled seat filters (Navigator, Lincoln LS and Aviator).
ADDITIONAL INFORMATION: If vehicle is registered in California, the California Air Resources Board (CARB) has determined that failure to install a new fuel filter at this interval will not nullify the emission warranty or limit recall liability prior to completion of the vehicle's useful life. It is, however, recommended that maintenance checks be carried out and recorded at the indicated intervals.
Natural gas and propane vehicles also require checking the fuel tanks and installing a new filter (propane vehicles).
56,000 Km (35,000 Miles)
64,000 Km (40,000 Miles)
72,000 Km (45,000 Miles)
Inspect automatic transmission fluid level using dipstick, if equipped.
If filled with green engine coolant, change coolant.
80,000 Km (50,000 Miles)
88,000 Km (55,000 Miles)
96,000 Km (60,000 Miles)
Additional checks for natural gas and propane vehicles at this interval include inspecting fuel tanks, as well as draining coalescent fuel filter and installing a new filter.
104,000 Km (65,000 Miles)
112,000 Km (70,000 Miles)
120,000 Km (75,000 Miles)
Inspect automatic transmission fluid level using dipstick.
Install a new cabin air filter.
Change green engine coolant, if equipped.
128,000 Km (80,000 Miles)
136,000 Km (85,000 Miles)
144,000 Km (90,000 Miles)
Additional services for natural gas and propane vehicles include inspecting fuel tanks, as well as draining coalescent fuel filter bowl and installing a new filter.
152,000 Km (95,000 Miles)
160,000 Km (100,000 Miles)
Inspect accessory drive belt(s).
Install new spark plugs.
If filled with yellow coolant, change coolant or at 5 years, whichever comes first.
Install a new PCV on all cars and light trucks under 6,000 pounds Gross Vehicle Weight (GVW).
168,000 Km (105,000 Miles)
Inspect automatic transmission fluid level if equipped with dipstick.
Inspect engine coolant system and hoses.
176,000 Km (110,000 Miles)
184,000 Km (115,000 Miles)
192,000 Km (120,000 Miles)
Install new accessory drive belt(s) (Escort).
Install a new PCV valve on all cars and light trucks over 6,000 Gross Vehicle Weight.
Install a new camshaft belt on all 2.0L, 4-cylinder engines (Escort, Focus, ZX2 and Escape).
ADDITIONAL INFORMATION: Additional services for natural gas and propane vehicles include inspecting fuel tanks, as well as draining coalescent fuel filter bowl and installing a new filter.
200,000 Km (125,000 Miles)
208,000 Km (130,000 Miles)
216,000 Km (135,000 Miles)
224,000 Km (140,000 Miles)
232,000 Km (145,000 Miles)
240,000 Km (150,000 Miles)
If filled with yellow engine coolant, change coolant or at 8 years, whichever comes first.
Change automatic transmission/transaxle fluid and filter.
Change rear axle lubricant on all rear wheel (RWD) vehicles.
Install a new accessory drive belt(s) (if a new belt has not been installed within the last 100,000 miles).
ADDITIONAL INFORMATION: If vehicle is registered in California, the California Air Resources Board (CARB) has determined that failure to install a new fuel filter at this interval will not nullify the emission warranty or limit recall liability prior to completion of the vehicle's useful life. It is, however recommended that maintenance checks be carried out and recorded at the indicated intervals.
Additional checks for natural gas and propane vehicles include inspecting fuel tanks, as well as draining and installing a new filter.
Exceptions To Normal Schedule
Yellow Coolant
Change coolant at 5 years or 160,000 km (100,000 miles) of the vehicle's life, whichever comes first.
After the initial change, change coolant every 3 years or 80,000 km (50,000 miles) thereafter.
Natural Gas and Propane Vehicles
Inspect NGV fuel tanks from the date of tank manufacture every 3 years.
Inspect propane fuel tanks from vehicle build date every 5 years.
Install new NGV fuel tanks from the date of tank manufacture every 15 years.
Normal Vehicle Axle Maintenance
Rear axles and power take off (PTO) units containing synthetic lubricant and light duty trucks equipped with Ford-design axles are lubricated for life. These lubricants are not to be checked or changed unless service is required, or if a leak is suspected, or the axle assembly has been submerged in water.
The axle and PTO should be changed anytime they have been submerged in water. Non-synthetic rear axle lubricants should be replaced every 4,800 km (3,000 miles) or three months, whichever occurs first, during extended trailer tow operation above 21°C (70°F) ambient and wide open throttle for extended periods above 45 mph.
The 3,000 mile lube change interval may be waived if the axle was filled with 75W140 synthetic gear lubricant meeting Ford specification WSL-M2C192-A, part number F1TZ-19B546-B or equivalent. Add four ounces of additive friction modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent for complete refill of Traction-Lok rear axles.
The axle lubricant should be changed anytime an axle has been submerged in water.
Police and Taxi Vehicle Axle Maintenance
Replace rear axle lubricant every 160,000 km (100,000 miles). Rear axle lubricant change may be waived if the axle was filled with 75W140 synthetic gear lubricant meeting Ford specification WSL-M2C192-A, part number FITZ-19580-B or equivalent. Add four ounces of additive friction modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent for complete refill of Traction-Lok rear axles.
http://www.jcwhitney.com/autoparts/...00992/p-2000992/N-111+10201+600003758/c-10101
TRANSMISSION OIL COOLER.
Advanced-design, and low-pressure-drop.
Honeycomb plates provide multiple oil-flow paths.
For cars, light trucks and RVs.
Stacked plates provide up to 30% more cooling than old-fashioned tube-and-fin coolers. Prevents transmission failure, and radiator boil-over. Dissipates heat quickly, and efficiently with minimal effect on transmission oil pressure. Almost 95% of all premature transmission failures are the result of overheated fluids. Even normal driving puts tremendous strain on cooling fluids, raising fluid temperatures up to 200° F and more! Corrosion-resistant aluminum alloy is stamped, and oven-brazed into effective cooling honeycomb (11/32" barb connectors). Air circulates on both sides of each plate, heat escapes directly from surface to air. Super-strong stacked-plate construction is vibration proof, and resists damage caused by road debris. Mounts easily to radiator core. No drilling required. Includes hose, clamps, brackets, tube fittings, bolts, and instructions. NOTE: Adapter fittings required for installation in 1983-1995 Ford cars, trucks, and vans sold separately (item ZX858099).
hi, is mercury mountainner 2005 is equipped with zerk fitting?
Original parts no. If replaced with aftermarket, possibly. Best way of finding out is by physically looking. ;)
