All I ever used was Lysol sprayed from the outside with the system on outside air and high fan speed. I even used Lysol on large commercial systems over the years.
It's under the passenger side cowl where the hood meets the glass. You can also set it to Max AC which uses inside air. If you drop the glove box, you'll see the fresh air intake box.
