good rim web sites? | Ford Explorer Forums
good rim web sites?
metstalker
Atl, Georgia
94 Ford Explorer XLT
i am looking for some black bullet hole rims for 1st generation explorer and cant find any. any help will be appreciated.
have u checked 4wheelparts.com?
truckxpressions.com
tellico4x4.com
desertrat.com
4wheelonline.com
what are the specs on the factory rims
dont hold me to this......but i think
15 x 7
16 x 7
i think it is the 15x7 just b/c the rims are 15 inch thanks mo guy
i thought of buying those also.......the only problem i had with them is the width only goes to 8 inches, which means you shouldnt put anything more than 10" wide tire on them
try looking around for a 10" wide rim unless you arent wanting that wide of a tire and you'll probably want a 3.75" backspacing (i think thats right) to push the wheels out just a bit to keep them from rubbing anything
so those would be good with factory type tires
do you think i can get a second opinion on what size rims will fit factory type tires how much back space and how may lugs
IIRC factory are 15x7
4.5" backspacing
5 x 4.5 bolt pattern
thank you all
