So, I get a little time this afternoon to finish up my "won't shift out of Park" problem on my F150. I had replaced a couple of the bushings on the shift tube that weren't allowing the plunger to fully "plunge." Put those on, and it still won't shift. So, then Hartman's "hard time shifting out of Park" thread popped in my head, so I looked and found that my brake lights weren't working either (I know, start with the simple stuff first). Check the BOO fuse, and it is blown. Replace it, lights work and it will shift now. Come inside for a few minutes to look at a couple of wiring diagrams to see what else is on the circuit, and see what I should check out to determine a possible reason why the fuse blew.
Head back outside, and smoke is billowing from underneath the hood. Open the door, pull the fuse I just put in, pop the hood while grabbing a 5/16", and disconnect the battery.
When the smoke cleared, the MC pressure swith, and harness, are pretty much fried. This switch acts as the brake deactivation switch for the cruise control, and is the part that may have a "slight" chance of catching fire and is being recalled. Watch, I will probably get the recall notice in the mail today!!
If you own one of the vehicles under the recall, I would definately recommend disabling the cruise control (or just unplugging the pressure switch).
