Got a few questions for ya'll | Ford Explorer Forums
Mint95Limited
Statesville North Carolina
'95 Limited
:salute:First off i thank anyone who responds to my questions as i am new to using this forum.
Questions 1. I am doing a TT and i orded 2 inch shackles from copperhead Fabrication. My question is will 33X12.50's fit and look good? i heard they rub but noone ever said how much or if they only rub when making sharp turns.
Questions 2. I really want to do the Foglight mod which everyone calls the "Brown Wire Mod" but i havent found anyone who has done it on a 95 or 96 with some information on what color wire. I am mechanically inclined but i dont want to go cutting wires trying to find hot and i dont have acess to alldata for a wiring schematic.
Any help would be greatly appreciated!!! Thanks!!:exporange
The brown wire mod is a transfer case mod, not fog lights. What are you trying to accomplish?
33's will probably rub a good amount with only a TT. Sheet metal cutting will most likely me required.
Im trying to get the foglights to work with the clearence lights and when the high beams are on, not just the lows..
-- what exactly does a brown wire mod do with the t-case?
wow youre right thanks! do you know how to do the foglight mod on the explorers to make the foglights work all the time not jus when the Lows are on?
I mean i know basic electronics, all i really need to do is find which pin on the relay is the Power source which if i remember electronics course right it should be 87 or 87A and then run a constant hot jumper wire from a key on accessory to replace the hot wire for the original foglight circuit and then i should be able to use the foglight switch to turn them on n off no matter what other running lights are on. but last time we tried this i made a new Hot for the switch with a jumper, and it ended up frying my switch. and the jumped was even fused! Thank god for junk yards lol
