srvblues00
- November 22, 2001
- Denver, NC
- 94 Sport / 88 Turbo Stang
A CE light has been on for a while now, and today I finally had time to work with it and see what was going on. Today I came back from the gas station, and as I pulled into the parking lot behind my dorm, I put the clutch in, and my X died!! Luckily, there was a spot pretty close by and I was able to coast it in. I checked fuel pressure at the rail, and that's fine. I then tried to start it back up. It did start, idled for about 15 to 20 seconds, and then died as if I turned it off with the key. I plugged in my code reader, and here's what I got:
Hard codes
335 - Pressure Feedback EGR (PFE) sensor or EGR Pressure Transducer (EPT) - signal voltage higher or lower than expected.
Continuous Memory Codes
327 - EGR Valve Position (EVP) sensor, Pressure Feedback EGR (PFE) sensor or EGR Pressure Transducer (EPT) - signal voltage too low.
332 - Insufficient EGR flow
I am thinking I will replace the EGR valve and see if that clears up anything. Then, if that doesn't work, I'll start replacing sensors. Why in the heck would the engine not run? Even if the EGR is bad, it should still at least run, right? Oh, I did check for spark, and we're good there. Any ideas?
Hard codes
