flathead40
- August 30, 2023
- Fowlerville Mich,
- 2006 XLT
On a 2006 XLT where under the dash does the gray vacuum line that goes to the heater control valve origanate from under the dash? On the 06, 4.0 when you turn the heat down or the a/c is called for vacuum goes to the valve to close it. I bought a new valve thinking that was the fix, and tested it before installing it by hooking too the gray vac line and it stayed open on cooling just like the orig valve. The a/c and blend doors all work fine. Is there a some sort of diverter behind the control panel in the center dash? Asking before I take the dash apart. Thanks for any help!
