Kawazar
- December 29, 2005
- Manchester, NH
- 97 Mountaineer
I have 2 different problems I need help with. The first is, when I change gears, lets say from drive to reverse I get a clunking noise. It makes the same noise when going back. I think that is the universal joints right? The noise comes from the drivers side front like it is the front driveshaft. It also clicks when going real slow in reverse or forward from the same area. The other noise is a constant grinding from somewhere in the front end. I think it is a wheel bearing. How can I check to see if the bearing is bad? Do I have to pull the bearings out? Thanks guys.
