5.0inprovo
- October 25, 2004
- Provo, UT
- '98 xlt
I have a few questions, searched and was unable to find my answers so here goes.
I bought my Ex two months ago, I love it. It is a '98 5.0 w/ 85k. Now that I have had it a while the little things are getting to me, so here goes.
1. Over Christmas parked at the airport for 4 days in sub-freezing temps, when I got back and tried to start it, it wouldn't turn over right away. The first 3 attempts at starting just produced the desil effect, as some call it, where the motor rocks and knocks for a second after the starter stops, but doesn't turn over. On the 4th attempt I floored the gas pedal and it finally fired. Starting has been rough since, but after it is started it still runs fine. I have recently changed the plugs, but nothing else.
2. The driver side rear door doesn't activate the cab lights. I realize it is connected to the latch inside the door, but I don't know if there is a fuse associated with it, or if there is a wire disconnected inside the door, or what.
3. The shocks are shot, still on the stockers, I realize there are hundreds of threads on this, but I must ask again... Do you get what you pay for in shocks? Many say no, and I am cheap. Are cheaper shocks going to last a while, be less soft and so on? I am looking for the most smoothe road ride, I RARELY off road.
4. The transmission was serviced the day I bought (pan off) it and the fluid seemd fine. It shifts fine except for on a cold start 2 to 3 shift takes forever to happen. After the first time it goes away untill cold again.
Thank you in advance for any help.
Dan
Dan
