Sorry
- March 20, 2016
- Western NY
- 02 Explorer xls
Just over a month ago, I posted a thread about having issues get getting my TCC to lock, coupled with the OD light and a 741 code. I took my other vehicle out of town for a couple weeks, came back, and figured I'd drive the explorer until something went wrong, and shop for a tranny in the mean time.
During that time, aside from a light flashing, everything has seemed just fine. Shifting was smooth and timely. No noises. No lack of power. Everything seemed fine except not having lockup in OD... until yesterday.
Driving to the greenhouse, I felt a slip and grab. But immediately after, it was fine and it kept going without issue. I parked in the parking lot, went in, came out, and started it up. It immediately lunged forward as if I just put it in gear. Ok, maybe I just fell off the pawl, since I was on somewhat of an incline. Put it in reverse to back out, no "reverse lunge". I go to back up, let go of the brake and immediately start moving forward. Shift back to park, then back to reverse, same thing. Cycle through the gears... Park, move forward until the pawl catches. Reverse, move forward. Neutral, move forward. Drive, move forward. Low gears, all the same. Except... I've never noticed before, because I never use it, but my selector won't go to 1. PRND32.... and it won't go into 1. But maybe that's normal? Don't know, but if not normal, maybe related.
So I turned the vehicle off while in neural, and pushed myself out of the parking spot. Go through the gears again, same thing. Decided to just try to get where I'm going. Put it in drive, take off, goes just fine, as if nothing is wrong.
Later on, I tried neural. Still the same. But I found that neural will only go through first gear, won't shift higher. Switch to drive, and it works fine. Goes through all gears, first through overdrive just fine. Smooth, timely shifts. No noises, no smells, no shakes, no power loss, nothing weird.
Seized clutches? Linkage issue? Something in the valve body? I'm stumped. I found a 73k trans for $450. I may be having to go get it in the morning. If I do go get it... any recommendations on checking or updating anything in it while it's out of the vehicle?
Thank you x hundreds
