hyperexplore
- May 8, 2006
- Boca Raton FL
- 2008 EB Explorer
2000 Mercury Mountainer 5.0 V8 . Hard starting, takes 3-4 key cycles for it to start and run. Runs fine, recent new fuel pump, changed the fuel filter. Getting codes PO171 and PO174 - lean banks 1 & 2. Apparently this can be caused by a vacume leak, which I'm trying to find. I also heard it can be near the PCV valve which so far seems impossible to get to unless i take off the intake plenum. when I changed the fuel filter I attempted to depressurize the schrader valve on the fule rail but no pressure released. Sprayed carb cleaner all around intake maifolds areas and no change in engine speed. Put on vacum gage and showed on the low side of normal.
