Hard starting. | Ford Explorer Forums
Hard starting.
Eric Campbell
Santa Clarita, CA
'99 Mountaineer
My '99 Mountaineer is requiring long-cranking or multiple tries to get the dang thing started! Seems like fuel to me 'cause it has plenty of cranking power and no indication of ignition probs. Any thoughts?
I was having similar problems when my engine was cold. I followed the advice found here regarding the intake air control (IAC). Pulled mine off and cleaned it with electric contact cleaner. Problem solved.
Thanks for the welcome! The "check engine" light is not on (sometimes, briefly, but not often at all). I just cleaned the IAC but I'm not sure that's the culprit. The engine seams to choose when it will act up...not necessarily on a cold morning. When it finally kicks in it's more like an on/off switch turning on all of a sudden. Does that give you any indication?...
