slowsn
- June 22, 2009
- mcminnville, tn
- 98 EB Explorer
just picked up a 98 EB explorer with the 4.0. truck has HIGH miles at 169,300. its clean, runs great and shifts good. got to doing some reading on these sohc motors and about the big TSB on the timing chain. now im paranoid. i'm hoping mine has been changed (all 3 ). i called my local ford dealership to give them the vin to see if they could pull up any service records. she said she wasnt able to view anything over 10 years old.
couple questions-
is there any way i can find out via the vin number if this truck has ever had the timing chain, tensioners, etc? i would think i could tell by listening to it but sounds normal to me. no slapping or grinding noise from what i can tell.
if it was making noise, its pretty noticeable - right?
the TSB that i read said for 99 up 4.0's. is the 98 4.0 exempt from the TSB? or do the 98's present the same problem?
im assuming not ALL 4.0's have this problem either?
thanks for any help and info, much appreciated
couple questions-
