have a chance to get a 90 BII | Ford Explorer Forums
FutureX
SF Bay Area CA
87 BII XLT 4x4
ive got a chance to pick up a 90 BII for 300 ... however theres a catch
the truck has been reg since 05, and it wont turn over, it will crank but just wont turn over...
how big of a problem can this be? i dont want to pick it up for 300, and end up with a $1000 investment as im already going to be in the hole with the tags most likely....... its got the basics run down of whats in a BII...
Depends a lot if you can do your own work. It could be a lot of things. Bad fuel filter, bad fuel pump, bad electronic module, bad coil, bad wiring, bad ignition switch, broken cam gear, blown head gasket and I am sure there are others that I missed.
im going to look at it the next couple days, going to pull out my code reader and see what kind of codes it throws...
