Have you experienced this? | Ford Explorer Forums
mdhsas
BRAZIL
weener
So my 2004 mountaineer AWD makes a light but high pitch grinding noise only when I turn right as well as has a horrible wobble on the freeway. While driving at higher speeds in order to continue traveling straight I must slightly turn my wheel to the left and then all of a sudden the car will jerk to the left and wobble back and forth a bit. It's super annoying and I would like to see if anyone has experienced this before or knows what it could be before I gotta take it to the shop. Thanks!
Aaron
Most common problem are the wheel bearings, and yours has that symptom. I'd get it fixed right away. You will probably need an alignment too.
