articfox
- August 11, 2013
- Winston-Salem, NC
- 2002 Ford Explorer
My mother has the 2002 Eddie Baur Explorer, so I am not to up to date on Explorer Troubleshooting, but I am no stranger to Fords! What problems I am experiencing are the following (Not sure if the problems are connected or not):
1.Keypad Entry Inoperative, Keyfob still able to lock and unlock car.
2.Key in ignition alert and Dome light, stays on door is open or closed until ignition switch is turned to the on position. Must put dimmer switch all the way off to turn this off
NO DOOR AJAR ALERT SHOWN ON MESSENGER CENTER
If it is a fuse problem, please direct me to the correct fuse because I am looking through the manual and cannot find a fuse that would cause such issues. Thank you in advance for your information.
