Headlight problem | Ford Explorer Forums
Headlight problem
stormrider151
Griffin Georgia
2003 Sport trac XLT
:confused::frustrate:banghead:On the way to work the other morning I hit the brights and the road went away. No bright headlights. All that was working was the passenger low beam and the fog lights. I replaced the bulbs and got my high beams back but the driver side low beam is still out. I bought anouther bulb. No help. Replaced the fuses (3). Ditto. I probed the wires behind the plug and no power to the low beam wire. I put a dollar value on frustration and right now I'm up to $1395.26. Any ideas? Thanks
well, you probably know the wire is broken somewhere, just run a new wire from the passenger side lowbeam to the dirvers side.
